Network
Just returned home from Italy and I can't get the network working. 48 doesn't even show up in the list of network operators. I've paid my Mitch membership already and, as my Wi-Fi can be slow, I really need my Internet. Thanks.
6 REPLIES 6
This isn't an iPhone by any chance?
I suspect not as you seem to be posting from a Sony?
If it is an iPhone then see here but adjust for 48:
https://www.tescomobile.ie/support/question.aspx?id=135
If it's not an iPhone then try powering off, taking the SIM out, gently cleaning the SIM contacts, reinserting the SIM, powering on and doing a manual scan for networks. If you see 48 (or O2 or Three?) then try to manually connect.
Make sure that data roaming is still enabled.
If that still doesn't work then you may need to contact 48 support for more advice:
No unfortunately
What exactly did you try?
Did you contact 48 support as I suggested?
Yes I'm waiting for them to respond
Did you get this sorted?
