25-01-2014 10:07 PM
25-01-2014 10:35 PM
25-01-2014 10:33 PM
Iv the very same problem since this mornin so ur not the only 1 iv had no service all day
25-01-2014 10:35 PM
25-01-2014 10:47 PM
iv an iphone so it auto rechecks network
26-01-2014 11:57 AM - edited 26-01-2014 06:34 PM
Hi folks
There could be an issue with Area Mast's...as mentioned, this can be resolved by booting the handset.
Inclement weather can be instrumental in this (if it is Mast trouble) which I would say is fitting, for at least, those near the coast North of the country were battered to a pulp again last night...
26-01-2014 12:05 PM
Any relevance here?
Working fine for me right now - Dublin 1/7.
26-01-2014 12:31 PM
Hey
Turned phone off made no difference
Manual carrier selection done and 48 or o2 were not in the selection Rochfortbridge is jus outside mullingar co westmeath
26 hours out now
26-01-2014 12:35 PM
Probably won't make any difference but try powering off, pulling the battery out for a few mins, pulling the SIM card out and then putting everything back together and powering on. If you lose your APN settings reconfigure them. Make sure that data roaming is still enabled. Then scan again for networks.
Do you know anybody else on O2 or 48 who is still seeing the networks OK?
26-01-2014 12:58 PM
Hey
Iv had iphone turned off and made no difference .
Took out the sim card last night and gave it a wipe but didnt help either .
I also know 3 others in the same area with the same problem .
I had to go off yesterday when i was away i got coverage back but when i returned home the coverage went back the same to no service
26-01-2014 03:24 PM
Hi Carolineush
Do you mind posting Back your Own/friend's area, it would be helpful...
