26-01-2014 05:56 PM
26-01-2014 06:17 PM
Hi beano2012
There are a small number of individuals whom, like you are reporting signal trouble.
From your post, I assume you have total signal loss... There has been an update from one of the 48 Techie Lad's on Data connectivity loss here http://community.48months.ie/t5/Techie-Updates/Lost-your-3G-connection/td-p/19319/jump-to/first-unre...
But may not be the answer to your case... Can you post what area you are in ? It would be helpful...
27-01-2014 09:06 AM
28-01-2014 08:03 AM
