Network down again
viv1cobh
Can't make or receive calls or texts again
You posted this already.
I replied to your other post here:
http://community.48months.ie/t5/Need-Help/No-service/m-p/35580#M13532
margaret2007
Cant make calls for the past few days no constant network available
Can you receive calls?
Can you send/receive texts?
Can you use data?
Where are you located?
Has anything changed on your phone?
Try switching off, taking the SIM out, GENTLY cleaning the contacts, reinserting it and switching back on.
Try manually scanning for networks and manually connecting to 48.
Can you try your SIM in another unlocked phone and see what happens?
If none of this helps then perhaps a replacement SIM might help:
Need a new SIM?
If necessary contact 48 support.
