Nano Sim Problem
w4nn13
I have a Nexus 5, I have no problems with any other nano sim from O2, Vodafone or Three nano sims but 48s Nano sim is just to small and is not recognized by my Nexus 5 just says no sim in phone? its seems to be a mm or 2 short compared to my previous sim, anyone know a work around or had this problem before?
Thanks
w4nn13
marionh
Crew (retired)
Crew (retired)
Hmm I thought Nexus 5 takes a Micro SIM and not a Nano SIM.
You can order a Dual SIM from 48. It contains both a Micro SIM, and a regular-sized SIM. To get the Micro SIM you just pop it out of the regular SIM to which it is attached. Did you try this?
See the 2 SIM photos here: https://www.48months.ie/free-sim
The nano SIM is the smallest one and it sounds like that's the one you tried to use with your Nexus 5, and it's too small for it. It's for the new iPhones.
Let me know how you get on? 🙂
