Internet roaming
Hi. I'm pretty sure I just paid for internet roaming, the 1gb for 3euro but I don't think it's working on my phone. Can you check to see if it went through
Sarah. My number is *********
Edit / personal details removed. -Marion
marionh
Crew (retired)
Crew (retired)
Hi Sarah. Do you also have active membership at the moment? It's needed for calls/texts/internet to work.
Only the 48 agents can check things on your account, you can contact them via this link.
