My text/data/voice history info
mc_bige
Hi, my 1gb data seemed to get drained more then normal last month, I normally never go over 1gb data.
Is there a way I can see what time, date, etc I used my data. The same for text would also be good. Like what you can do on tesco mobile
Thanks
The only way to get such info is to ask 48 support for it as the My 48 account page does not list it.
There are also apps or, in some cases, utilities built into the operating system to track data, text and call usage.
