My internet won't work abroad
john32
Hi I am going to Ibiza in the morning and every time I am there my internet won't work only when I get wifi ,is it my settings or do I need to put some credit on my top up,i have a iPhone 4 thanks
John
Unfortunately 48 don't support data while roaming abroad.
You'll have to make do with wifi access wherever available while you are abroad.
Other call charges
"Data roaming can be expensive, so we don't support it right now. We recommend you go find a local WiFi hotspot!"
Other call charges
