Moving over but want to keep the same number
Hey . Can someone help please . I recently registered my sim and am in the process of waiting for it to moved over from
Vodafone . ( I did this about an hour and a half ago ) . When I checked my email - it said to verify its me by clicking the link - when i did so - it said here is your new mobile number . I don't want a new mobile number . I want to keep my own number ! Will my number port over as it was or will I have to use the new number ? Cos im not interested if I have to change numbers . Thanks
Read this:
http://community.48months.ie/t5/Most-Popular-Questions/How-do-I-keep-my-old-number/td-p/18
If you still have a problem then log a support request to get 48 to help:
Hey,
Inside your new SIM Pack there should be all the information you need to keep your current number.
Go check out the sim pack and im sure you'll be able to fix this!
Iv already done this - but no joy I'm afraid . I'm worried now ill be left without a phone number or with a new number I don't want .
Read this:
shellyspill
Help ???? I've just signed up to 48 also same problem... I want too keep same number & be on 48 network ... Can someone help me this is frustrating as I need answers ... I've mailed 48 4 times& no reply from
Them
If you want to keep your old number then see here:
How do I keep my old number?
Just one email/help request to 48 will do the trick eventually. If you keep spamming them then a response to your query will just be delayed.
Guide on how to get help
