Mobile data
bfitz
My mobile data keeps turning on and off repeatly wen i turn on wifi hotspot..i cant use hotspot now cause mobile data wont connect..plz help..tanks
bfitz
Oh i just joined de 48 network today..
Are you sure that your internet/APN settings are configured correctly?
Can you access internet OK from the phone apart from the hotspot?
bfitz
Ya internet works fine..just hotspot won't..worked fine before on meteor SIM card..
bfitz
Got it workin ..another apn was on De fone aswell..deleted it..problem solved..
Glad you got it sorted.
