MEMBERSHIP
stefy_88
Hi!
I charged my sim yesterday with 20 euro in order to renew my membership that expires today. Instead of the DON I chose the MITCH. it took the money out but I still don't have gb, calls or text, why??
If your membership expires today then that means tonight at midnight.
Then the new membership will kick in.
Your online account should clarify the fact that your current membership is still in place, it runs until tonight and the new membership is stacked ready to kick in after midnight.
If you have used up allowances on your current membership then you need to buy add-ons to tide you over:
Add-ons
Add-ons
Thank you 😄 I have my membership :)) thanks for your help
Glad you got it sorted.
