I lost my phone
alan
I lost my 48 phone sim and have blocked the number and applied for a replacement sim.Will I be able to keep my old 48 number and credit that was on the lost sim?
The replacement SIM will be on your existing account/number and your membership etc. should be intact as long as whoever has your phone now hasn't used up any membership allowances or credit balance between when the phone was lost and when you deactivated your SIM by ordering a replacement.
Thanks for that.Cheers!
Glad my post was useful to you.
Just noticed ... the replacement SIM order form says:
"Is your 48 sim lost, stolen or faulty? don't worry, here you can block your sim, re-order a new one, and still keep your number and credit. nice one."
The same thing happened to me, how do I actually order the replacement sim with the same number I had?
It's explained in this key topic:
See under "I’ve lost my SIM (Phone)".
