Keeping number
I've registered my new 48 sim card and my phone is unlocked but still haven't received a text with a security code. Any suggestions??
OK - assuming you entered the correct phone number, network and bill type info then there must be something wrong that will need you to log a support request to get 48 to look into it for you:
The security code text is sent to your old number/SIM/operator network. You need to leave the old SIM in the phone until you receive it. Don't insert the 48 SIM until this step is complete. Does that help?
Old sim card is still in and haven't received the text
