Invalid email address and can't top up
I've tried topping up through the 48 app with a saved card and it's saying there's a problem with my card.and when I try log in on a computer it's saying invalid email address can anyone help?
Are you sure that you're entering the correct email address?
If so then I think you'll need to contact 48 support about this:
