Internet
My phones Internet was fine and it just stopped workin all of a sudden sayin DNS failed or request timeout when I go to use it!
There was a bit of an outage on some or all 2G connections last week but 3G was working at the time and 2G was eventually also fixed.
I just tried both now (D1/7 area) and both work fine for me so I don't think it's a general outage.
Double check that the APN settings are still OK - it's unlikely that they spontaneously went wrong but you never know...
Try rebooting the phone just in case (I know, I know - standard IT support advice! Man LOL)
If you cannot get it working then you might need to contact 48 support:
