Internet
mauracremin
I can't get the internet working. I have tried changing all the settings etc and it has not worked. It just tells me You have lost data connectivity. My phone is also permanently on roaming for no reason and i don't even have the romoing button ticked :L help please
You need roaming/data roaming enabled for data to work!
Make sure that the settings are correct and enable data roaming and it should work.
