Internet
israel18
hey am told by 48 that there is no APN settings for htc desire 310. what do i do
Try the online configurator. The 310 is not listed but maybe try this:
http://48months.tweakker.com/choose/HTC/Desire%20300
Or else another similar model:
If that doesn't work then download the Tweakker APN app from the Google Play Store over wifi and run it and it should configure your settings correctly.
