Internet won't work anymore
roisin_moore
I went to Spain and when I came back my Data just seems to have stopped working. My 3g and Roaming are turned on and I've tried ringing directory enquires (which sent me to an eircom line???) But it still isn't working. I've also manually reset all my APN settings and still nothing. I have the Don membership.
Do calls and  texts work OK?
Are you using an iPhone (don't think so from the device id displayed on your post)?
If so then have you tried switching from the roaming profile to "local" profile - e.g. see here but adjust as appropriate for 48 rather than Tesco:
https://www.tescomobile.ie/support/question.aspx?id=135
I don't understand the bit about directory enquiries and what that has to do with the issue?
