Internet setup problem
Hello I have a Nokia lumina 520 and am having problems with the Internet settings I've followed all the instructions but it still won't work
When you used the link did it send a configuration message to your phone?
If so then what are your settings now?
Make sure to enable data roaming as this is needed.
If not then try the manual configuration using the appropriate link or the generic settings:
Windows 8 phones
Windows 7 phones
Internet Settings
If all that fails then contact 48 support:
Did you try the online configurator?
http://48months.tweakker.com/choose/Nokia/Lumia%20520
Did that not work?
I'm assuming that you have a current membership and data allowance (either via your membership or a data add-on)?
If it doesn't work then maybe post your settings here for review.
I am a current member and data was included in my membership. The link you provided was the one i followed that wouldn't work for me
Windows 8 phones
Windows 7 phones
Internet Settings
