Internet settings for iphone not working
I did this but I can't use the Internet
You mean you tried these settings but they did not work?
http://community.48months.ie/t5/Need-Help/Settings-for-Apple-iPhone-3G/m-p/144#U144
http://community.48months.ie/t5/Need-Help/Settings-for-Apple-iPhone-4/m-p/146#U146
Does anything else work - e.g. calls and texts? If not are you sure that your phone is unlocked, your SIM registered/activated etc.?
If necessary you should log a support request to get 48 to assist/advise.
