Internet roaming
craig7
I am currently in Hungary and my internet roaming isn't working. I have configured my device to the correct APN Settings, but still can't connect
Are calls and texts working?
Are you on a Guido membership?
Is your APN field set to 48months.liffeytelecom.com?
If not then edit it to change it to that, save the change, switch airplane mode on and then off and then see if it works.
This APN field problem is a common one for people roaming in the EU.
Did that help at all @craig7?
