Internet not working with 4 weeks
My internet has not been working with the last month and I keep losing signal.
Did it ever work?
Is it just in the past month it proved problematic?
Are your internet settings correct?
http://tinyurl.com/kys43lv
If all else fails you need to contact 48 support - the link above explains how.
Did it ever work?
