Internet not working after holidays
My data will not work since I returned from holidays on Saturday evening. I have used the tweaker multiple times since then (recieved four messages at once this morning) and followed the steps correctly, but no luck. I have a Samsung S6, have not run out of data - Don membership, have mobile and roaming data turned on. What can I do?
Seems to happen with Samsungs for some reason.
Manually check your settings against the ones here and change them if necessary:
If it still doesn't work then post your settings (ideally screenshots) for review.
Any update?
