Internet is not working on my mobile
usern
Hi I bought The Don offer on 15/05/2013. I'm able to make calls but I'm not abke to get on the web. I was on FAQ page and did add all the settings for my Samsung s3 mini. Name: 48month Apn: 48month.liffeytelecome.com Mms http://mmc1/servlets/mms Proxy 10.1.11.19 Port 8080 Mcc 272 Mnc 11 Apn type Internet, mms Authentication PAPBUT IT STILL DOESNT WORK????
Can you try using the Tweakker APN app to configure your settings and see if that helps? The links are in this thread:
If not then you might need to log a support request to get 48 to assist:
6 REPLIES 6
Your post was blank.
Did you mean to ask a question?
If you are trying to configure your internet settings then try the steps here (in spite of the link name these steps are not specific to Samsung/Galaxy phones):
raymon
Hi I have tried everything to get my Internet working when abroad but is still won't work. I did everything that was suggested to me by yourselves still not working
Where are you?
What membership are you on?
What make and model of phone are you using?
What is the APN field of your internet settings set to?
Have you contacted 48 support?
Any update @raymon ?
