Internet add on wont work
rebeccaf
I bought the internet add on afew days before my membership ran out, it will not work now my membership is gone, i was under the impression i could use this add on when my membership ran out, how do i fix this??
You need an active membership for add-ons to work.
It's mentioned on this page which is linked from the add-on purchase/checkout page.
Add-ons: To use an Add-on you must have an active Monthly Membership.
If you buy a memberhsip your add-on will work again.
