Internet Not Working
sucram
I've tried everything on your trouble shooting section for the internet. Everything is in order. Phone settings membership etc but mobile data just isn't working. This problem started when I returned from Germany. Please help its becoming very irritating having to constantly leech WiFi. Thanks. Marcus
dc888
Crew (retired)
Crew (retired)
Hey sucram
Have you also ensured data roaming is switched on.
If you do then I think you might need to delete your APN settings and start from scratch again.
So delete any saved APNs and ensure you have following settings entered.
Name - 48 Internet
Proxy - leave blank
Port - leave blank
Username - leave blank
Password - leave blank
Server - Not set
MMS proxy - 10.1.11.19
MMS port - 8080
MCC - 272
MNC - 11
Authentication type - PAP
APN type - default,supl,mms
That should do the trick.
Damian
Those settings with Authentication type = none work for me. So I don't think that the Authentication type setting matters? As I mentioned here:
http://community.48months.ie/t5/Need-Help/Internet-amp-amp-MMS-settings-for-Asus-Padfone-S/m-p/33181...
Hi Damien,
Tried your suggestion and redid my APN but still no luck. I made sure mobile data and roaming were turned on but it still isnt working.
What next?
Marcus
dc888
Crew (retired)
Crew (retired)
Can you take a few screen shots of what you have saved and attach them to your reply.
I'll need to cast my eye over them.
Thanks
Damian
APN type seems to be the one that trips most people up.
Make sure that it's APN type = * or APN type = default,mms,supl.
