Internet Explorer
nitrogen
Hi everyone,
just wanted to ask if anyone else is having problems with connecting to the Internet, my phone was working until this morning and maybe this is only a problem in the north west.
I can make calls just no internet again,
m
I've lost data a few times in the last few weeks.
Powering off/on always rectified it.
Double check that your internet settings are still ok too.
Hi nitrogen
Can you power off and on your handset & check connection...
The weather was pretty wild...could attribute to local mast issue's.
After the power cycle, any luck?
Smiley Happy
Many thanks for all the help,
the turning on and off didn't work but this morning the coverage was back,
thanks again to both replys,
m
Glad you got it sorted one way out another.
