I recently bought top up and used it to get The Guido but I Cant use ANY of my text and internet all
thestarten
I cant use ANY of my text and because i bought my phone from china i cant get the spacific data pachage to upload on my phone what can I do, PLEASE HELP
If you can't text then make sure that your SMSC is correctly configured. Normally this should come from the SIM automatically but maybe sometimes you have to manually configure it. On Android you often configure it like this:
http://www.empirion.co.uk/android/setting-the-smsc-sms-message-centre-in-android-ics/
See also this link for the 48 SMSC:
Problems sending a text
To use the internet you need a data allowance (via membership or add-on) and you need to configure your APN/internet settings. Try all of the steps here:
http://tinyurl.com/kys43lv
What China phone make/model is it?
