I paid for "The Don" ??? Not working
trycan
Hello Crew & helpers Cat Very Happy
I paid for "The Don" Earlier , It Went Threw cos I got the following page after saying it was a success!! The Money Was taken from credit card cos I got that checked? But it Says on my 48 page Im still on "The Guido" what is going on ? Please help??
My guess is that you bought the Don membership while your existing Guido membership still had time to run to the end of its monthly period. Buying a new membership does not prematurely terminate a current membership that still has time to run. It will stack and kick in when the current membership has expired. If you have used up calls/text/data allowances on a current membership then you may need to buy add-ons to tide you over. Buying a new membership such as the Don will not help immediately - only when the current membership runs its course.
30 REPLIES 30
Can you check your SIM in another unlocked phone?
You may also need to contact 48 support directly at this stage.
Use this link to do this:
