I am on hols in Salou can't seem get 48 network what do I select need help
ohsocool
You won't get the 48 network abroad.
You just connect to one of the local networks.
Remember that you will need cash credit to cover the cost of roaming services if you don't have eu roaming add-ons. Also data roaming won't work so you'll have to use wifi where available.
