Huawei Ascent P1 internet?
Looking for internet setting for the Huawei Ascent P1!
Have looked through everything, tried the generic settup and other ones I found in the FAQ section but doesnt work.. Does anyone know them?
Thanks
i have same phone, used tweaker app from play store. everythi was done in few sec.
Hi, have you tried using the internet settings that apply to the phone most similar to yours? that is something worth looking into.
