30-05-2015 04:23 PM
30-05-2015 07:01 PM - edited 30-05-2015 07:06 PM
I wonder if the Nokia Network Setup App might help at all?
Maybe also delete all APNs and then start configuration of the Internet and MMS APNs from scratch in case that helps?
I presume that this FAQ doesn't help...
http://www.microsoft.com/en-us/mobile/support/faq/?action=singleTopic&topic=FA141648
Do either of these links help at all?
The second refers to the first but has additional info.
I realise that they refer to Tesco but since they're another virtual operator on the O2/Three network the info may still be relevant (if you obviously substitute the 48 settings for the Tesco equivalents).
https://www.boards.ie/ttfthread/2056712402
http://www.boards.ie/ttfthread/2057403118
Apologies if any of these are wild goose chases... ![]()
30-05-2015 07:48 PM
30-05-2015 08:51 PM
Was the phone used on another network before?
Just that some of the links mention this causing a problem if you move to another network and maybe necessitating a factory reset and reconfiguration of the settings...
30-05-2015 11:40 PM
03-06-2015 10:27 PM
Did you ever manage to get this sorted?
03-06-2015 10:31 PM
03-06-2015 10:33 PM
That's a bummer. I wasn't able to find any other reports of this or solutions by Googling unfortunately...
03-06-2015 10:36 PM
