How do I convert my top up?
How do i convest my top up into membership ? i just top up on line Tara
sauce
Hello Tara,
Welcome to the new 48 Community Forum!
Your membership is one of the 4 available.
and
Your Top-up is used to pay it! Simple's.
You can find a more indept answer here: http://community.48months.ie/t5/Most-Popular-Questions/How-do-I-buy-my-membership/m-p/6#U6 .
I hope I helped. If I did dont forget to leave Kudos!
If this response was helpful make sure and accepted my answer as the solution. And of course +1 kudos.
~ Alan 48 Community helper
sauce
Hello Tara,
and
fingle
how do i convert my top up
You mean how can you buy a membership or add-on and pay for it using your cash credit balance?
You can do this by text:
How do I buy stuff by text?
Or online from your My 48 account:
https://www.48months.ie/membershop?cat=memberships
