How do I change current my number over to 48?
Hi there I want to activate my 48sim and use my previous number the problem is my previous number is not activated so I can't receive any texts or voicemails to it... How can I activate my 48sim?
You will probably have to contact 48 support directly to ask them if/how this can be done. The key post says that the number being ported needs to be active and if it's not then you need to get the old operator to reactivate it in order to receive the porting security code. I don't know if there's any way around that requirement.
How do I keep my old number?
Hi coheafa
Did you achive your aim? Did you get the previous sim card activated to go through the porting process?
Can you post back to let us know how this worked out for you,as other's have found themselves's in a similar situation & would benefit from your experience!.
