Hi. What membership do you have to have when going aboard and you want to use your 48 sim card?Thank
Hi Larisa19
If youre going abroad, you simply but a Roaming Add-On
Here is where you can buy it, https://www.48months.ie/buy/roaming-packs
Yours,
Camille
Community Helper
Hi Larisa19
Yours,
Camille
Community Helper
Is this sorted for you, Larisa?
Thank you!
@camsterr wrote:
Hi Larisa19
Not necessarily - if you are travelling to the EU then a roaming add-on may save you money on your call/text costs but it's not necessary and roaming will still work without them.
See here for more info:
http://community.48months.ie/t5/Need-Help/going-abroad/m-p/7254#M2333
