30-05-2015 02:23 PM
30-05-2015 03:04 PM
Does your 48 SIM work at all?
Using the new 089 number it came with?
But when you call your old number your old SIM works?
Did you submit a number porting request?
If so, when?
You may need to contact 48 support if you requested a number port but it has not happened after a few hours.
30-05-2015 03:04 PM
If so, when?
31-05-2015 10:24 AM
31-05-2015 10:25 AM
