hi , I recentley signed up for 48 and i got my sim. i was previoously on meoter and i regersteried my sim so i was no longer with my last network but when i put my 48 sim in it asked me for a network dismiss key i dont know what that is but i think i need to get my phone unlocked. so i rang meoter for my unlock code and they said this pin and i put it in but it didnt work and  then i rang them again and said that that pin didnt work  they wouldnt give me any other pin but they said to ring the shop i bought my phone from to get a pin so i did and they said that only meoter willl give it to you but they wont how can i get it unlocked ????
kevinoism
Regular
Basically go to the shop and tell them that they have to give it to you. You already rang them and got a code off them so I'd go back to the shop with that code and ask them to unlock it for you . If that doesnt work ask them to ring meteor for you to get the code as they must give you the unlock code requested. The shop can say all they want about you having to ring them up but really they can do it too so don't be swayed by them.
Alternatively you can get it unlocked by an unlocking store. This will cost you about €20 though.. So I recommend that you keep pestering meteor to give you the correct code (as there have been times that they have given the wrong code and that could be the case here) and save the 20 quid if you can.
I hope this helps somewhat, If you need help about unlocking or the stores that do it , i can tell you where to go in Galway and Dublin!
kevinoism
Regular
Depending on the phone make/model you may be able to get an unlock code for free or for less than €20 online - e.g. eBay. As ever with eBay only buy from reputable sellers.
