HELP NEED CREDIT NOT ADD ONS
I've just bought add ons but should have selected credit as I need to call a 1850 number a.s.a.p? How do I change it to credit please?
You need to contact 48 support.
Only they can possibly refund the cost of the mistaken add-on purchase (if the add-on has not yet been used) and/or convert it to cash credit instead.
In case it helps there are often regular landline alternatives to common 1850/1890 numbers and those would be covered by your membership/add-on landline allowance and may work out more cost effective in some cases:
http://www.saynoto1890.com/
