Does 48 SIM work in Nokia 2G phones?
GordonOK8492
Hi,
I'm buying my Dad a phone that has a long battery life and very basic functionality, like the Nokia 105. Will 48s sim card work in this 2G phone?
As far as I know it should work fine assuming it's unlocked for use on any network.
But maybe double check with 48 support that a 2G only phone will work ok on the 48 network just to be sure.
This thread suggests that it should.
https://community.48.ie/t5/Phones/What-frequency-is-used-for-voice-calls/m-p/50190
Hi Dalyer,
I can't access the link on this old post. Just wondering if you know if a 48-sim card will work on the 2G Nokia 105 phone?
Thank you,
I can't find the original thread either.
As far as I know a 2G phone should work on 48.
See here for example:
"An older device will continue to support data services on the 2G network but with slower data speeds."
But coverage may not be as good as 3G/4G.
You might want to check here:
Hiya did you get an answer to this? Bought my son as Nokia 105 but the sim won't work!! Can't really find an answer anywhere. Thanks
