13-09-2026 10:28 AM
13-09-2026 11:07 AM - edited 13-09-2026 11:07 AM
Do you mean that membership plan auto-renewal failed and you had to update your registered payment card details?
If so then auto-renewal will not retry after you did this and you'll have to buy your next plan manually before auto-renewal takes over again next time around.
If that's not the issue then what happens when you try to buy your next plan manually?
Any error messages?
