Divert my number
jb14
need to divert my number for a few weeks to a different number because I'm goin on holiday wat do I do
I don't think that 48 supports call diversion other than to voicemail:
How do I use my Voicemail?
It's been asked a few times before but I've never seen an authoritative answer. If necessary ask 48 support and maybe post the reply back here for the benefit of others?
If you are travelling to the EU then if you buy an EU roaming calls add-on then incoming calls will not cost you anything but maybe you want to avoid calls altogether? 🙂
Did that help?
