Data working and then stops
juliar99
I have my data working for 20-30 minutes and then it disconnects and I don't have data at all even when I turn it off and on again. I have to restart my phone to make it work. Please help?
Assuming that your APN/internet settings don't change then you may need to contact 48 support about this issue:
Is there any way that you could try your SIM and data access (which would require configuration of the APN/internet settings) in another unlocked phone just to check that it's not a SIM problem?
Did it ever work reliably for you?
