- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report this post
09-06-2014 02:38 PM
Hello,
I found out 48 connection (signal) on my phone goes off and off repeatedly since yesterday. Full bar E (EDGE) then 4-Bar 3G, 5-Bar 3G , 2-Bar 3G then No Service at all. Then the same cycle occurs until now.
Area: Wilton, Cork
Phone : iPhone 5S ios 7.1.1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Report this post
09-06-2014 02:49 PM
Ok - you probably need to contact support so.
See the link that I posted above.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Report this post
09-06-2014 02:41 PM - edited 09-06-2014 02:43 PM
So it was working fine before this (for how long?) and only started doing this yesterday?
Did anything change on your phone - e.g. software update, sync with iTunes, SIM removed and reinserted etc.?
Try powering the phone off, taking the SIM out, reinserting it and powering on again - any difference?
Anybody else in your area on 48 and having the same problem?
Do you have another unlocked phone that you can try the SIM in?
You might want to contact 48 support in case they can advise:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Report this post
09-06-2014 02:48 PM
Exactly, it's only started doing this yesterday. I dont do any software update. Yes I did turned my phone on and off. I'm not sure whether other 48 users in my area have the same problem or nit. I dont have other unlocked phone with me right now is my other phone cannot use the nano-sim
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Report this post
09-06-2014 02:49 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Report this post
09-06-2014 03:22 PM
Thank you 🙂
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Report this post
10-06-2014 08:12 PM
I'll be back in Ireland on September and if the same problem happens, I would conclude that there is something wrong with my phone (or O2 doesn't repair the distruption issue in my area )
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Report this post
10-06-2014 08:42 PM - edited 10-06-2014 08:43 PM
You mean you are not in Ireland now?
Does the phone work OK where you are now?
As usual it's a process of elimination to get to the root cause.
E.g. is it the SIM, phone hardware, phone configuration, network etc.?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Report this post
10-06-2014 08:53 PM
No, I'm still in Ireland right now & I will enjoy my summer break abroad. If I had the same problem when I come home in September, then I'll take another step to solve this problem.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Report this post
10-06-2014 08:55 PM
If you had the time and the means it would be worth trying...
- Your SIM in another unlocked phone
- Another 48 SIM in your phone
- Another carrier's SIM in your phone
as it might shed some light on the problem.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Report this post
11-06-2014 01:01 PM
