Conference Calls
Hi, wondering are conference calls supported on 48? iv tried merging calls but it doesnt seem to work 😞
Some operators seem to restrict conference calling to specific contracts - e.g. business contracts - or provide their own special facilities for conference calling separate from any handset options for merging calls - e.g. I found this for O2 (on whose network 48 largely operates so this may be relevant):
http://www.o2online.ie/wps/wcm/connect/O2/Home/Business/Business+Solutions/Voice+services/Group+conf...
If it didn't work for you then I presume that 48 does not support it but best to log a support query to get the definitive answer from 48 support:
JakubO7578
I have exactly the same problem. In my profession I totally rely on conference calls. I have recently switched to 48 and even though I did everything that was required in order to be able to merge calls, I still cannot do it. I can have several calls at the same time but on separate lines so I can switch between them. Unfortunately, I cannot merge them and if the situation cannot be resolved I will have no other option but to change the provider.
Here is what I have already done.
On my iPhone 6s I have set up the following:
Cellular Data
User: user
Password: [blank]
LTE configuration
User: user
Password: [blank]
MMS
User: user
Password: [blank]
Proxy MMS: 10.1.11.19
MMS maximum size: [blank]
URL of UA profile for MMS: [blank]
Personal Hotspot
User: user
Password: [blank]
What else can be done? The MERGE button is active but pressing it does not do anything.
You realise that you're replying to a 7 year old thread?
Anyway I don't believe that anything has changed in that time and am pretty sure that 48 (still) don't support such a feature.
But as mentioned in my previous reply you should contact 48 support to clarify for sure.
