Change plans
newgarden1
Hi my guido membership is due to expire and automatic renew , how do I switch to don plan? And am I fixed on that then or can I change if it doesn't suit. Thanks
I already answered this question here:
You need to change your automatic renewal settings to choose Don rather than Guido.
newgarden1
Sorted thanks
MichelleT1254
Can I change my plan
Yes, just choose the plan that you want from the options presented on your Buy Plan page.
By the way, you replied to an 8 year old thread which seems a bit odd...
