Cannot pay for my membership...
I always use my credit card,and im sure it always works,but it has been a week since i cannot top up my 48...it says "There has been some problems with your 48 account" the whole week...any ideas?
You would be best to log a ticket straight away with the 48 crew they will check things out-hopefully you can get up and running again-meantime, consider buying a top-up voucher then following the guide to selecting the membership of your choosing.
Hope you get sorted soon!
i will try that 😉 thanks
