Cannot connecr to 48 network
cdaz
Hello, it seems froma week ago I cannot connect to 48 network. I searched manually for networks and 48 is listed there,but when i try to connect it tells me error while trying to connect to this network. And sometimes when I'm looking manually,no network appears at all. It happened to me before a year ago,and then it fixed,but is happening again,can someone help me?
Many thanks in advance!!
What is the exact error that you get?
Have you tried switching off, taking the SIM out, gently cleaning the SIM contacts, reinserting/reseating it, switching on and trying again?
Perhaps the SIM is faulty and you need to try a replacement?
Need a new SIM?
You might want to check with 48 support first though:
