Can't send texts
Hi!
I have a problem, every time I try to send a text, an error message appears 😞
I start the number with +353, but it seems it doesn't work.
Thank you
What error message?
Can you receive texts?
Did sending texts ever work?
Can you make and receive calls OK?
Is your SMSC configured correctly?
Problems sending a text
Are you testing an Irish mobile number? Remember that international texts are charged from your cash credit balance (25c each).
Other call charges
What make/model of phone are you on?
What does your online account say about your membership status, expiry date and text allowance balance?
Any chance you are sending long texts which your phone converts to MMS and which cost 30c each to send (charged from your cash credit balance)?
What error message?
Other call charges
Did you drop the zero when you added the +353?
Good point! 🙂
