Can't send texts to a specific number
aomoran
Hi,
I cannot send texts to a friend's number, although all other texts send without a problem. What do you recomend?
Thanks
You probably need to contact 48 support and ask them to investigate this issue. It seems to happen to specific users from time to time for some reason...
iv  same problems to 2  087 numbers
