Can't make/receive calls/texts
Djodib6298
You need to post more info in order to get assistance from the Community Forum.
Were you ever able to use these services?
Or are you just trying to get started on 48?
Did you successfully activate your SIM?
Do you have a connection to the 48 network - i.e. signal bars etc.?
Your My48 account Dashboard will tell you if you have:
